hobbimaster
03.16.2008, 12:07 PM
Ya, if you are using a spektrum system be aware, that once you turn on the TX then RX it usually takes 1-2 seconds to communicate. This is usually the time you need to get into programming mode, or radio set-up. The best way around this is to use a RX battery.
Castle has now addressed this issue in there software update by allowing a delay in the ESC to allow 2.4Ghz users the time needed to get to programming mode. All ESC manufacturese need to do this, I beleive
I had the same issues with a Novak a while back.
