Losi LST2 Brushless
Fast5sRevo88
Losi LST2 Brushless - 03.21.2008, 07:56 PM
I was thinking about converting an Lst to brushless(didn't want to buy from that FineDesign guy) and wanted to use a Neu motor with a 6s lipo and since the truck has mech. brakes, use a Castle HV 125. Would use Monster Pro if the Castle doesn't work, anybody know which Neu i should use? Maybe Mike could make me some good motor mounts so i don't have to.
jzemaxx
03.21.2008, 08:09 PM
The CC 125 is not the HV model, its only good for 6S. The HV model is rated for 12S.
bluonyx
03.21.2008, 08:29 PM
So on the airplane models (HV110) you can use the same setup as the MM models? Like forward/brake/reverse (proportional w/reverse lockout)? It that's the case why haven't I bought one!
03.21.2008, 08:54 PM
None of the cc air escs, inc the hv110, have proportional brakes. You must also use a pixstix adapter so that they will work with a wheel radio.
entjoles
03.21.2008, 09:04 PM
i have been interested in this also , now that i have mech. brakes on my truck i may try this, anyway can someone post a link to a pixstix, i couldnt find it on tower , and dont know where to find one, thanks
aqwut
Brushless Heavy Weight....
aqwut's Avatar
03.21.2008, 09:23 PM
HobbyCity Turnigy 6S-100Amp ESC is working great in my Brushless LST on 6S and 9XL... $65 ESC + $14 PiStix.... works great!!
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Fast5sRevo88
03.22.2008, 11:44 AM
The CC 125 comes in the regular and HV model.
Fast5sRevo88
03.22.2008, 11:58 AM
True, it doesn't have proportional brakes, but it does have brakes. I don't need em though because the Lst has mech. brakes. I don't know anything about pixstix, but the CC rep. that i talked to didn't mention using pixstix to make it work with my wheel radio.
jzemaxx
03.22.2008, 12:11 PM
Hmm I have yet to see that.....its not on the CC website.
Screw-Up
Fast5sRevo88
Screw-Up - 03.22.2008, 12:47 PM
I'm sorry about that, i meant the HV110, my bad!
03.22.2008, 03:24 PM
Pxstix is available from rchydros, who make it.
Or get it from offshoreelectrics.com.
Fast5sRevo88
03.22.2008, 07:13 PM
Found it, that website is on my favorites, right under my nose.
Feigo 7XL Motor
Fast5sRevo88
Feigo 7XL Motor - 03.23.2008, 06:14 PM
Do ya'll think that a Feigo 7XL motor would be a better choice than the Neu 1521?
bluonyx
03.23.2008, 10:11 PM
I have a Fine Design XLT1 in my LST2 which is basically a 7XL. I just ordered a Neu so I'm hoping it'll make a huge difference. I got used to the XLT motors and want more now.
03.23.2008, 10:41 PM
I have an aftershock, and intend to use a KB 45 12xl motor on 8s-10s lipo. Leaving the stock 2 speed and using Mike's 2 speed adapter, which I had him bore out to fit the KB 6mm shaft.
Going to leave the mech brakes and use a CC hv85 esc with a pixstix adapter. Most likely going to use a pair of 2200 20c 5s lipos wired in series.
Batteries should be good for nearly 2hp, hope that is enough. I may have to buy some larger capcity 5s packs, we will see.
