03.22.2008, 04:40 PM
Hey Matt, From what I have read you can't reverse the motor. Now you may be able to remove the sensor assembly and flip it over and then swap 2 of the main wires, but that is just speculation by me. I am also guessing that you cannot flip the axles over? It is kind of annoying that the software does not have a feature that wil let you reverse the motor's rotation. Novak should have built that in, or offer some sort of software fix.
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
03.22.2008, 05:02 PM
Maybe you could program the esc backwards like instead of going to full throttle first go to full brake, then full throttle, then neutral. It's worth a try.
