Chapito
03.23.2008, 08:23 PM
The tire diameter input is too large. A slightly worn crime-fighte is only about 110mm.
Brian's calc. shows around 35k and 40mph with a 3200kv motor on 11.1 volts with a 46 spur, 14 pinion, and 4.2 inch tires in an 1/8 scale buggy.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
03.23.2008, 08:35 PM
Alright, thanks, when I was on Tower Hobbies to check the size the Badlands were the 1st one to come up so I just used that size. Changing it to 110 makes big difference. Running a 4S on the same gearing works out nearly the same as the badlands
