Revracer
Revracer's Avatar
03.23.2008, 11:38 PM
see i used my integy 3 shoe and they slip like crazy. i might try the M2C clutch. got nothing already put so much money into it might as well spend some extra money experimenting. and i do a lot of on off stuff since i mostly drive in relatively small areas. so i need something that wont heat up much and will work fine with that.
david lamontagn
03.24.2008, 12:06 AM
So the best thing for you will be tu use the RCM mount with pinion to spru setup.
