03.27.2008, 10:12 AM
Forgot to add that I will be using mech brakes, and the 125 quark is the air version, so it will be forward only. I figured that it should handle 6s lipo without having to handle braking duties. Brake servo will be custom mounted sideways, and the motor will still on the radio tray side. That will leave the other side of the truck for the esc and battery tray.
04.07.2008, 04:37 AM
Looked at this truck more, and decided to do a custom rear bake setup, much like the new hyper9 buggy. It would place the rear brake disk on the rear diff pinion cup, and a brake pad holder would sit right in front of that cup. The holder would have a hole to let the dogbone pass through, and also have the brake lever conventionally mounted on the top. A single, long linkage would connect the front and rear brake levers, and the servo would be positioned right behind the steering servo, between it and the front center diff bulkhead.
I am doing this because the motor will be in the way of the rear brake disk if it is left on the rear center diff bulkhead. Plus I think it will be cool looking, and different!
