Maxxman
03.28.2008, 08:04 AM
Honestly, it isn't that hard. You just have to go slowly up and down with the disc at an angle to the shaft and make sure that you have a pinion available to check the shafts size. Just don't do too much at a time and if its close to sliding on use a bit of sand paper or something similar to get the last little bit off.
