satttheman
satttheman's Avatar
03.30.2008, 01:52 PM
I Was Goin To Use The Adapter That Mike Makes To Use The 30mm On The 25mm Motor Mounts. Im Thinking About The Pinions And The Shaft. I Dont Think I Can Bore Out His Hardened Pinions. So Wat R My Other Options I've Heard Ppl Dremeling There Shafts Down Does That Work Good. And For Esc Ill Just Use My Hydra240 It Should Hold Up Good On 6s(i Hope) I HOPE THAT WILL FIT ON THE MOUNT TO ITS NOT AS LARGE AS THE SENTILON BUT ITS BIG
Projects:
FLM Savage
