rcmonkey
Team Thermal Racing
rcmonkey's Avatar
05.03.2008, 06:40 PM
Thanks, thats pretty quick Whats your runtime like?
My Rides:
Tamiya Dark Impact - Team Losi Micro B - Cen Mini Madness - Soon to be BL Xray XB8 TQ
brushlessboy16
brushlessboy16's Avatar
05.03.2008, 06:56 PM
I Gunned it at 48 on a freshly repeaked pack and cool motor and esc.
I am getting about 25 minutes of Runtime till the cutoff
im on my second set of rear tires already though. :D
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
05.03.2008, 07:05 PM
As in 48mph? Sweet
My Rides:
brushlessboy16
05.03.2008, 08:13 PM
Indeed 48 mph. i realized i never actually did have my pack peaked... i had it at 4.1v per cell. i just set the charger to delta peak and the cells are each at 4.19
Five-oh-joe
05.03.2008, 08:22 PM
What kind of temperatures are you seeing on the motor, ESC and batteries?
brushlessboy16
05.03.2008, 08:24 PM
Ugh well my temp gun got trashed(spilled epoxy on it..) but the batteries had absolutely NO heat in them, the esc was pretty warm but i could hold i finger on it. the motor was HOT. but that was partially my fault b/c i increased timing on it.
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
05.03.2008, 08:35 PM
Was the motor running cool before you increased the timing?
My Rides:
brushlessboy16
05.03.2008, 08:45 PM
it was hot, but i could hold a finger on it for a few seconds. im gonna fiddle with the esc to find the sweet spot
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
05.03.2008, 08:58 PM
Hmm, do you think maybe the motor is a bit fast?
My Rides:
brushlessboy16
05.03.2008, 09:08 PM
it could be, but mind you this motor has no heatsink, no fan on it, same with the esc (yet) running on 5s. you cant expect it to stay ice cold :D
Five-oh-joe
05.03.2008, 09:09 PM
So the zippy packs work good then? I was considering them for some of my RCs (and possibly a big project)...
brushlessboy16
05.03.2008, 09:25 PM
definately!! i love mine, that and the imax b5 charger is awesom too
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
05.04.2008, 10:40 AM
Could you measure the distance between the mounting holes on the front? I may have come up with a cunning plan.
My Rides:
brushlessboy16
05.04.2008, 11:56 AM
Right now im at my Nana's house with the raze, ill scan the little spec sheet that came with the motor for you. What might this plan b?
Ive run 2 packs through the raze today, my rear tires are slicks now... but the problem is i keep losing hardware... never to be found again
05.04.2008, 01:56 PM
Maybe have Mike make you a heatsink to put on the spinning part of the motor, then it would also create a huge fan blowing on all other components which should (hopefully) make them run cooler as well. May totally not work but it was worth throwing it out there.
