xcntrk
xcntrk's Avatar
04.01.2008, 08:29 PM
Note that the CastleLink is only intended for the CC-BEC and other (non-MM) controllers. The Mamba Max specifically is only programmable through the on-board USB port, not the 3-wire receiver terminal. I too ran into this issue recently and it’s clearly stated in the Castle Link software (great interface btw). Also you can program the CC-BEC while it’s installed/interfaced with your ESC. You simply have to “turn-off” the enable/disable toggle switch for the ESC and the CC-BEC will sync right up.
