Cain
04.05.2008, 11:28 AM
Well, if I recall with the RC Monster motor mount I think a 15T pinion is the smallest without mods you can do. For me, with a 2.5D motor it appears a 17T pinion is a starting point, going to a range of about 19 - 20T pinion. I would say for you, maybe start with a 16T pinion to start with.
If you are set on ordering a Mamba Max now, Let me know, I have one that has the RC Monster UBEC (the white one) on it already installed and a 12V fan installed too that is much more durable than the novak one that I could be interested in selling.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.06.2008, 11:40 AM
The RC-Monster mount itself doesn't limit the gearing - it will accept down to an 12t for sure (probably 10 or 11) all the way up to a 25t - all our mounts are designed with this capability with the stock spur gears(designed for 12-25t with some "fat" in the adjustment). The limiting factor would be the motor diameter, as well as other items on the car(such as the rear chassis brace on the RC8 in particular, as Bomb-proof pointed out). FYI :)
