blueb8llz
04.06.2008, 04:00 PM
ok got it. then i wont be charging/balancing them in series then. much easier to just set the lvc at 12.8 haha. thanks again.
lutach
lutach's Avatar
04.06.2008, 04:06 PM
I run my packs in series as well. I have adapters that I use to charge them in series or parallel. Just make sure before you start charging that he packs have equal voltage.
Fast5sRevo88
04.06.2008, 04:32 PM
I don't mean to hijack threads or anything, but if u have a single charger that balances while it is charging, how do u hook up both balancing leads on the two batteries, or do u have to?
Haltered
04.06.2008, 04:58 PM
You would have to make a harness to pull all of the balance plugs together for the balance tap on the balancer.
