04.08.2008, 11:03 AM
Originally Posted by jzemaxx View Post
In an emaxx a 1521 1.5D will push you over 70+ mph on 8S. ;)
That's 8s though. I would not like to burn a new MMM!! If they're anything like they're little brother, 8s should be just fine. I have a feeling I'm going to see a lot of "MMM Overvoltage Testing" threads. Or so I hope.
04.08.2008, 11:09 AM
How about this setup?
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 10
Total Voltage: 22.2
Motor KV: 1900
Tire Diameter (inches): 6.5
Tire Ballooning (inches): 0
Motor Current Draw: 110
Motor coil Ω: 0.005
Spur/Pinion Ratio: 5 : 1
Total Ratio: 14.23077 : 1
Tire Circumference (inches): 20.42 inches (518.68 mm)
Total Motor Speed: 41135 RPM
Vehicle Speed: 55.9 mph (89.79 km/h)
Effective Speed Rate: 2.52 mph/V (4.04 kmh/V)
Estimated Adjusted Speed: 52 mph (83 km/h) - 8% loss
Effective KV Value: 1852.93
Motor Torque: 0.41 ft-lbs
Final Torque: 5.8 ft-lbs
Final Power: 2442 watts (3.3 HP)
04.08.2008, 11:17 AM
Ok. I think I got my setup figured out.
Motor: Neu 1521 1.5d
ESC: MMM
Batteries: 2x 3s 4500mAh 30c FlightPower
Center Diff: HB Lightning
Diffs: E-maxx 3905 (for now)
Gearing: 10/50
Tires: mashers, mulchers, something 40 series
Wheels: something 40 series and 23mm
Axles: center dogbones, ft/rr: stock 3905
Chassis: FLM
What do you all think of that?
