jzemaxx
04.08.2008, 12:58 PM
Originally Posted by TexasSP View Post
The right body, body scissors, a knife, and a heat gun and you could rig up some good down force. I did this with my stock pede body and eliminated a lot of lift. You also want to be concerned about the rear at the same time because rear lift can cause the front to get squirrely and lift as well. If you are using a truck body, simply cutting out the tailgate section does wonders. Sometimes it just takes experimenting with different things.
You are right....my high speed XTM BL MT has the rear cut out and handles ALOT better at higher speeds now. Also a longer wheelbase does wonders. I can run 10S on the XTM truck and it will NOT lift off....just hazes the tires. Awesome BL truck.....I don't think my emaxx will ever be to the level of it, but I'm working on it.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
Fast5sRevo88
04.08.2008, 01:08 PM
jz, what do u use for brakes on that emaxx? The HV110 doesn't have brakes, does it?
jzemaxx
04.08.2008, 01:13 PM
No brakes per say like conventional ESC's but it does have a brake. I used castle link to put the brakes on 10% with zero delay and I just use them when needed. Very nice mild braking. When I don't want it to brake I just keep my finger barely on the trigger to de-activate the braking. Only with castle link you can change it to 10%. Manual programming only offers, no brake, 50% brake or 100% brake. 50% brake sends the truck flipping end over end....lol
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
