04.09.2008, 01:17 PM
A 7XL can run pretty hot - I found gearing a 9XL to be better - If it got hot enough to melt the solder on a motor lead I suspect dead. At a minimum I suspect you have blown some fets
No harm in trying to put it together but suspect you will be sending it to CC with $50...
I've toasted 2 MM on 1/8... 1 motor magnet cracked and one cogging combustion but with both of these I just ended up with a pile of carbon
