04.09.2008, 05:06 PM
Moly greases with 60% + molybdenum disulfide content:
Honda Moly 60 paste, $9 for 3oz, pn 08734-0001 at your Honda dealer, or $8 from Kim Leong, STOC 3073, California Sport Touring.
LocTite Moly paste, 65% molybdenum disulfide. $20 for an 8oz tube from Enco, part #505-1197, 800-873-3626
TS-70 Moly Paste, 4 oz. ctg. $14 from TSMoly. (800) 508-5545
An alternative to moly is the new poly-flourinated lubricants made by DuPont called Krytox Teflon Bearing Grease. These chemicals are simply magic. They have almost no known solvents, are chemically inert, and don't burn at any temperature, even in a pure oxygen atmosphere. This is pretty clearly the only grease to use. See this article. Nascar mechanics have found that Krytox grease can reduce the temperature of spline joints on drive shafts by 150°. Also, this stuff lasts forever. It is, unfortunately, quite expensive.
Krytox is compatible with moly - in fact DuPont sells a high pressure Krytox which mixes the two. You may hear some horror story from some mechanic about mixing greases and the result turning radioactive or some such. Don't worry, it won't happen with moly or Krytox.
Krytox greases:
DuPont XHT-AC extra high temperature anti-corrosive Krytox. $30 for a 2oz tube, pn 10195K25; $113 for an 8oz tube, from McMaster Carr.
DuPont XHT-BDX extra high temperature extra bonding Krytox. $63 for a 2oz tube pn 10195K22; $230 for an 8oz tube pn10195K24 from McMaster Carr.
LocTite Krytox HyperLube, pn 29711. about $35 for two ounces.
