04.09.2008, 11:10 PM
Got my medusa 36/60/1500 today. Motor looks nicely made, and the windings look good too. Packaging and labels are a bit cheap, but that is the place to save a few bucks IMO! I do not care for the color, but I will try the motor in my hyper8. Performance is what I am looking for!
kostaktinos_mt
04.10.2008, 03:35 AM
you got the v1 or the v2 version?
i think medusas are somewhat 'neu rip-offs'... the rotor is 4pole,segmented, and housed inside a carbon shell [instead of kevlar; i guess that saves some bucks,but it`s a lot better than nothing], and the stator is slotted [don`t recall if it`s 8 or 12 slots though -it`s been almost a month since i teared my 36-50-2200v2 apart to check the insides]. the construction seems solid, even though the motors are designed in usa but made in china i believe [that also helps keeping the costs down].
nonetheless, i think they are a good option for those average bashers out there, who [at most cases] are between a cheap feigao [or ammos and similar -disposable- motors] and an expensive neu [or lehner].
now what we want, is 70-75mm medusas for our heavy trucks
  Send a message via MSN to kostaktinos_mt
KaztheMinotaur
KaztheMinotaur's Avatar
04.10.2008, 12:35 PM
A longer can usually means more torque right?
83gt
04.10.2008, 12:57 PM
Yup, usually. More poles also equates to more torque, usually.
04.20.2008, 11:59 AM
I have the v2 motor. Looking inside the can thru the front cooling holes it appears to have a 12 slot winding. It really looks similar to the inside shot of the neu and plett motors that I have seen.
How do you get the can apart? I guess that the rear endbell is pressed on? I tried to disassemble an aveox motor that I had bud did not have any success.
lutach
lutach's Avatar
04.20.2008, 03:51 PM
My Aveox are easy to disassemble. Most motors have that back glued on and sometimes it makes it easy to heat it up a bit to soften the glue. One ? though, why do you want to disassemble it?
