mkrusedc
NeuMaxx
mkrusedc's Avatar
04.12.2008, 11:36 PM
I have a 3906. The largest pinion i could fit was a 20 tooth because the can diameter is so large. Neus are very efficient and should not have a heat problem. what kind of speed do you want?
wade7575
04.12.2008, 11:54 PM
If I get 40 to 45 MPH I'll be happy.I just want to make sure I do not want under or overgear and toast my ESC.I was looking at the Novak 6.5 but now I will not touch one because they want you to run a 12 tooth pinion and I know from doing alot of research nobody is making a 12 tooth 32p 5MM bore.Nice to see you on this board to and not just at the traxxas board.
