i will wait!
plettenbergs
plettenbergs's Avatar
i will wait! - 04.13.2008, 01:57 PM
i will give them a couple days to see if stock comes up!....i love the price!....i might work my way up to 5s....i am already having drive line issues!...WHAT DO YOU THINK?...i do not want to cook the esc,s
04.13.2008, 02:16 PM
its about time you go lipo! and you can't remove a pletty until we have video of the dual setup! Did you shear the roll pin of the input shaft? replace that weak pin with an allen wrench or drill bit, the tool grade steel lasts much better
that would be the pin!
plettenbergs
that would be the pin! - 04.13.2008, 02:32 PM
i considered a replacement pin....i do not want something loose inside my aluminum UlTRAMAXXED gears!....what will keep the steel from flying out?
04.13.2008, 02:37 PM
you need to use something large enough that it has to be pressed in. some even heat the shaft in an oven to expand it and then press in the pin. I ground the edges off an allen wrench and pressed it in with a vice and then dremeled off the excess. whether you go single or dual plettys I would do this upgrade, I've snapped two rollpins with a 6.5 hv maxx, and thats 1/5 the power of one pletty
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.14.2008, 12:43 AM
LOL... I used an allen wrench as well... I just pressed it in with a big bench vice..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
04.14.2008, 12:56 AM
HAHA, I did the same, gotta love the bench vise!
