bdebde
That's All Folks!
bdebde's Avatar
04.14.2008, 10:59 AM
I run a 1930/8 and a 1940/7 in my buggy, both on 4s. The 1930 works great if geared below 40mph, but starts to heat up if geared up too much. The 1940 will take any gearing I throw at it (so far), but starts to cut down on run time.
rchippie
rchippie's Avatar
04.14.2008, 12:21 PM
I ran a 1950 on 4s in my buggy. It was fast but not fast enough, only because i was using a 8T motor & i really needed a lower turn motor for 4s. A lehner 1940 7T would be very good on 4s or a 1950 6T.
REAL MEN RUN BRUSHLESS
jhautz
jhautz's Avatar
04.14.2008, 08:08 PM
1940/7 is a killer buggy motor. Great track motor on 4s and on 5s its a riciculously powerfull bashing motor.
My $0.02...
I have both Neu and Lehner motors and they are both flat out awesome. They both do have pluses and minuses though.
Lehner
(+) 2 pole works with any esc, 36mm can is "standard", Runs cool and super powerful
(-) Hard to get in the USA and expensive, 3mm motor mount screw hols are not the strongest IMO as they can be stripped is your not carefull. Weak support.
Neu
(+) Easy to get in USA, Powerefull and cool running, great support
(-) 4 pole means some ESCs struggle with them, larger than normal diameter can diameter, holes in the front of the motor arent the best for dirt driving IMO.
to make it...
or break it...
Silent...But Deadly
