fromdaboz707
04.14.2008, 11:43 PM
No def not a good set up! Unless ur picking one up dirt cheap stay away from it. The motors need the upgraded 5mm rotor to be reliable ($50) and the esc still can't handle that motor. I paid $230 for mine then another $50 for the 5mm upgrade and its useless now. My Mamba Max was $140 from my lhs, the CC BEC was $22 on here and an 8xl that already has a 5mm shaft was $62 so that is actually cheaper and more powerful. Or wait another couple weeks and get the MMM for $170 and you wouldn't need the CC BEC to run it on 4s LiPo so it pretty much cost the same if you can wait. No matter what though I recomend staying away from the Novak setup!
ok thanks for the info and are you shure taht the mmm will be 170? and can i pre order a mmm?
