Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
How-To modify your single speed trans to use the 3905 slipper clutch!
TDC57
TDC57's Avatar
Cool How-To modify your single speed trans to use the 3905 slipper clutch! - 04.24.2008, 01:53 AM
How to modify the output shaft of a Revo to accomdate the 3905 slipper clutch system for a Gmaxx G1 single speed or FLM 10000 single speed transmission.
Parts you will need!
1. Revo output shaft / Part # 5366
2. Traxxas second gear from a 3906 trans / Part #3933
3. Traxxas slipper clutch system part #5351 & 5352x
4. Spur Gear (your choice of stock or Mod 1)
Equipment you will need!
1. Drill press
2. Titanium Drill bit 5/64”
3. Bench grinder
Take out your new output shaft and use tape to as a guide, you will need to grind down the end of the shaft just below the end hole. See pictures below
Now use the first gear that come with you part #3933 as a guide to drill your new slipper hole. The new hole should be just past the original slipper hole. I use a axle nut to hold the gear in place so this way I don’t experience any movement and I'm insured a straight hole through the center of the shaft. See pictures below.
Nothing!.. Hahahahaaa..
