BOOGIE444
04.24.2008, 10:50 AM
Originally Posted by Sammus View Post
1) Probably, haven't tried those exact ones, but have used similar prices chinese cells that perform very well, havent tested the discharge ratings though. The ones mentioned on here are usually all korean cell based, which have a reputation for better quality (ie more accurate C ratings or less voltage drop under load).
2) Yes and no. Yes if all you want to do is do high speed runs. No if you ever want to drift or jump with confidence. The reason for this is they are designed for aero use and have a super low torque soft start (Which cant be disabled, it is very soft even when in 'normal' start mode) to protect fragile aeroplane gearboxes. With aircraft you tend to hold a fairly constant throttle. With land vehicles you tend to be braking and blipping the throttle a lot, and the soft start gives you quite a significant delay in throttle engagement (ie if you go from coasting to throttle to try and balance the car in a drift, or blipping the throttle to balance the car in mid air). This means unless you can compensate for this delay (which you cant really, you dont usually know your going to have to blip the throttle to bring the nose up in mid air before the nose actually starts diving), you will find it very hard to drive and jump consistently with. For racing there is no way you could get away with one. For bashing maybe, depending on your bashing style (if that makes sense..)
3) Put it this way, if I'd have known how bad the delay was in the turnigy HV esc (which I assume your talking about) I would have planned my whole conversion differently - maybe even never have gone electric in the first place! So YES, I would highly recommended spending the extra $$ for the mamba monster. If you still want to go with the Turnigy I have two I want to sell (with programming cards) that I'm more than willing to part with.
4) Can't really help you with this one, apart from say that I've had bad experiences with those cheaper no-name chargers, but cant speak for all of them.
I hope you gleaned something of use from my rants! :)
How much do you want for one of those turnigy esc???
Sammus
Sammus's Avatar
04.24.2008, 10:54 AM
I've sent you a PM (well am just about to :P)
BOOGIE444
04.24.2008, 10:55 AM
I have a imax b6 charger and I love it, no complaints about it what so ever, I even got the imax ac adapter so I can charge inside the house too. Its also a very easy to use charger that has alot of safety features on it too, plus it charges A123 cells too, not bad for a $65.00 charger.
I have zippy-R 4s 4500mah and zippy-H 6s 4000mah packs both packs deliever solid amps and work fine charge after charge. The only thing you have to worry about with these packs is their size as they are meant for airplane useage. So double check the pack dimensions vs how you intead to install them on your car / truck because in my experience they are longer & skinny'r than your average lipo pack ie... max amps or something.
And I also have the HV turnigy esc, yes they work great no cogging etc etc, and yes they have a really slow delay from a dead stop so if you think that is going to bug you save the $$$ and get the monster max.
