bdebde
That's All Folks!
bdebde's Avatar
04.30.2008, 10:51 AM
I ran ball diffs all around in mine, just ran them tight and locktited them, still had to rebuild often though. Switched to viscous diffs when they came out, then finally sold it.
lutach
lutach's Avatar
04.30.2008, 11:45 AM
Go crazy like I did . I did the following: 2 sets of viscous in the garbage. 2 sets of 3Racing ball diffs http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI and stripped the ring gear, got extra ring gears http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI, but tried them with this http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (Differential Pinion Gear GPM) and that failed. Got this http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (aluminum center locked spool) and this http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (MIP Hardened Steel Bevel Pinion Gears), it ate the ring gears pretty quick and waited for a solution. Got a set Atomic ball diffs http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI and http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (Steel diff spur gear), but they didn't fit the aluminum diff cases. Are you guys confused yet. Well I am . So after the Atomic ball diff din't fit, I almost sold my MLST. I tried the Steel diff spur gear with the 3Racing and it fits, but locks up the diffs. So I put the plastic ones that came with Atomics diff and now it works and has been working great, plus replacements are cheap http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI (Replacement Ball Diff Spur Gear). I tried it first with a low Kv YS22-3000 and now I have the YC22-5000. So all you need to get is the 3Racing ball diffs http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI, Atomic diff spur gears http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI and MIP Hardened Steel Bevel Pinion Gears http://www.thetoyz.com/cart/thetoyz_...&cat_name=MINI.
Edti: more info here: http://www.one18th.com/forums/showthread.php?t=57034. They should make a sticky with this one .
