Mod Man
05.01.2008, 06:07 PM
It is currently a 5345/14. The KV is 225. I would love 100 KV.
Can you rewind this? What would you charge me for it?
How high voltage could I run through it? I may have a line through Castle on a Beta 90 volt ESC. But, no big deal if not. I am currently running 12S.
Matt
sikeston34m
sikeston34m's Avatar
05.01.2008, 09:52 PM
Matt
The Biggest Problem is getting the Stator off the Bearing Holder. It's not just a little stuck, It's ON THERE! LOL
I don't know what the exact adhesive is that AXI uses, but it's some tough stuff. I posed this question directly to AXI and they told me it would release it's grip if it was heated to a temperature above 300 degrees.
So that's what I did, but the motor that I was working with, I had added some RED Loctite to the Endbell side of the stator. I noticed a little void, a little crack there where I could seep some more "protection" in.
I'm sure It would have been easier to remove if I hadn't have done that. 300 degrees in an oven later, it wouldn't even think of budging. It took 500 degrees and about 4 hours to get it off there. I could just barely wiggle it before it cooled enough to reset the adhesive. I almost tore it up.
500 degrees melted the coating on the old winding wires and "glued" them all together. It almost melted the coating that was on the stator and made it very difficult to rewind. The coating that is on the stator serves to insulate the stator from winding shorts. It also softens the sharp edges of the stator, so it's not so apt to shave the coating from the winding wires when they are being pulled.
I know you're really into RC and have alot of contacts for information. My Question to you is this, Is there an Adhesive Solvent that will help to break the grip without using so much heat that other damage occurs?
Once the Stator is removed from the Bearing Holder, Yes I can rewind it. It usually takes me about 5 or 6 hours to rewind one from this point.
I'm sitting here staring at a spool of 22awg winding wire that's rated at 200C. It's the good stuff. The coating doesn't melt until it reaches 392 degrees Farenheit.
I prefer to use the larger wire. It's a little harder to work with, but the end result is a motor that runs cooler and usually has a higher amp carrying ability than the factory ratings. It's also easier to come up with a greater Cross Sectional Area than the factory ratings thus more efficient and cooler running.
Why doesn't the factory use larger wire? Smaller Wire is easier to work with, easier on the workers fingers and easier to get a successful winding on the first try.
Can you tell what Ga. wire it's currently wound with? It's something like - 24 parallel strands of 30 awg wire for 14 turns.
Is there a thread here on your Bike? I would like to check that out.
It's not how much voltage you can run, it's how many amps your application will pull at the desired voltage. Operating Temp will determine the limits. If you intend to push it, consider cooling in your application. Airflow, and the heat sinking ability of Aluminum help tremendously.
Current Factory Wind is rated at 12S, and 110 amps for 20 seconds. We can bump that up some. How much, I'm not sure. This depends on the number of parallel strands of 22 Ga. wire that will fit for the number of turns that are used. (Stator Fill)
How much $ for this? Let me think about it. I won't choke you though.
