Ok, just read on there that you can run 3mm longer screws if you like. Im think the standard screws are 5-40 x 1/2" so what does that make it in 3mm longer? Don't deal with imperial sizes much.
Also, what are some screw sizes that you should keep on hand for the 8ight?
i just put the kit on and i did not have to use longer ones i used the ones that were in it just thought i would let you know thanks
If you don't have the balls to get a tattoo, don't b!tch about the ones who do!! Horsepower is how fast you hit the wall , Torque is how far the wall moved after you hit it
