mwry13
mwry13's Avatar
05.02.2008, 03:41 AM
I just sold my setup (financial issues) and it was purely a racing setup
4s Neu 30c packs
Neu 1515 1y/f
Mamba Max with the usual mods
BEC set at 7 volts ^_^ fast servos are the #&!*
Car really doesnt matter all that much... i found that kyoshos had a ton of room to play with... it took me a week or so of fidiling to find a CG i liked with battery / esc setup and all as well as the setup i used
8k front diff oil, 50k center, 3k rear
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
Neu 2s 5000 Mah 30c Batteries
M11 DSSS
Airtronics 358
Socal
cmcclive
05.02.2008, 08:34 AM
fiegos are cheap but they run hot (very hot I guess)
-Go with the MMM controller (castle has taken preorderes so I have to assume they will really release it when they say they will (end of may?) But I think the MMM motor is still in waiting. I don't follow castle, so I could be wrong.
-For racing 4s is sufficient, you could run 5s, but it would only be giving you more top end speed (which isn't what you really need on a track in my opinion).
-Most people go 5000mah to 6000mah, some go high (8000mah or more) to make absolutely sure they will have enough juice for anything. But a larger pack will add weight and slow you down.
-find an inexpensive roller, BUT it would be in your best interest to make sure a local hobby store sells spare parts for that brand/model.
rcsammy
buggy beater
rcsammy's Avatar
05.02.2008, 10:46 AM
thanks for the advice, looks like i will wait for the MMM
unfortunatly my lhs is very bad and overpriced so i dont shop there often, mostly buy my parts online... so the upside is that i dont have to worry too much about what chassis i buy
although i do like how the 8ight has the steering servo and receiver box way at the front which would make mounting the receiver easier/neater
will i need a BEC or a low voltage protecter if i use the MMM controller?
and what sort of runtime would i expect with a 4s/5s lipo pack?(unsure of mah yet need to have a look around... maxamps are cheap are they any good?)
  Send a message via MSN to rcsammy
