dubkatz
05.03.2008, 10:30 PM
the thing is 6s and a good efficient motor is gonna push(Plenty fast) any 1/8 buggy, truggy, monster truck no matter how much aluminum you have on it, and thats what the mmm is ment for. not to power custom 1/5 scale 25lb monster trucks. I run 14 old beat up, vented gp33000's. that on a 9xl is almost too much power for all but strait speed runs. keeping it on all 4's off the line is a chore, unless i loosen the sliper a whole lot. So someone tell me why 6s with a neu isnt gonna be enough? :P
05.03.2008, 10:45 PM
Well, for a start, higher voltage generally runs cooler, and allows for cheaper lipos, as the c rate and overall size can be smaller. Until you have run a hv setup it is difficult to understand the difference. Also, depending on the lipo, the lower amp draw due to increased voltage provides more performance at higher motor loads, as the batteries are not working as hard as a 4s setup would be. 6s is good, much better than 4s in my experience. Plus the cheaper feigao motors seem to run cooler at higher voltages, as their is less current going thru them. The higher voltage helps the ineffecientcy of the motor a bit.
lutach
lutach's Avatar
05.03.2008, 11:04 PM
lutach
lutach's Avatar
05.03.2008, 11:18 PM
Simple:
Lets say you're looking for 2HP or 1500 watts. With 6S you will need at least 68A to get that. Now if you had 12S all you would need is 34A. With 6S a good motor for a buggy would be the 1512/2.5D and for 12S would be a 1512/2.5Y. Now if you want a good motor for a truggy with 6S would be a 1515/2D and for 12S a 1515/2Y. Now those would be a nice choice for racing. Guess which motors will be more powerful, run cooler and more efficient.
