david lamontagn
05.04.2008, 08:56 PM
You're better with 4s and XL can for 1/8 scale buggy.
And you'll never been able to build an under 7lbs rtr 1/8 buggy, never
jhautz
jhautz's Avatar
05.04.2008, 10:53 PM
I don't know David... I'm getting REALLY close.
RTR, with the body, battery (4350mah 5s), Neu 1512, and even the body clips its only 7.14 lbs!!!! The new 808 is really light. I might even be able to shave a few more grams when I install the body that came with the 808. I'm using a pretty thick/heavy one that was on another buggy until I can get to painting the new body.
The weight without battery is 5.89lbs.
On 3s with a smaller motor I could probably get it sub 7lbs RTR.
Couple proof pics.
With battery RTR
No battery.
EDIT:
Sorry for the derail rootar. I'm with Glassdoctor. I think it can work as long as you dont expect it to be whipping up on the nitros the way a more properly sized setup would.
to make it...
or break it...
Silent...But Deadly
