lutach
lutach's Avatar
05.18.2008, 06:36 PM
Originally Posted by johnrobholmes View Post
Do these have the same fets as the air version? Just different programming?
The FETs on the one I have are the NXP PHK31NQ03L. I have suggested another FET from NXP that seems a lot better as it has much less resistance then the ones there now. I have also suggested 3 or more powerboards to handle higher current. I will post some pictures of what I will do to the unit I have. Good thing my Schulze 18.97 failed as I'm going to use the heat sink from it and the fan from my Novak HV controller. I'll probably do a little box to fit the controller in and use some left over capacitors to make a big capacitor bank to see if it can help in the heat issue. John, I'm very impressed with this controller. All the safety features works, it went into the 50% power before it hit the Thermal cut off. The switching BEC works like a champ.
johnrobholmes
johnrobholmes's Avatar
05.18.2008, 06:48 PM
I have been pleased with all of the products I receive from Scorpion. Out of hundreds and hundreds of outrunners I haven't gotten one single bad one, not one blemish. Of the few ESCs they have worked great for a great price too.
---JRH---
lutach
lutach's Avatar
05.18.2008, 07:15 PM
I like how the owner of Scorpion seems to want to build a very nice car controller. I gave him some ideas and he liked them. After I'm done installing the heat sink and fan, I'll send him photos of it. I sent him a photo of a very nice heat sink/ fan combo and I hope he uses it. I'll see if I can do the changes to this ESC ASAP and get it out for some more testing.
lutach
lutach's Avatar
05.22.2008, 01:39 PM
Some pictures.
ID:	4658   Click image for larger version
ID:	4659   Click image for larger version
lutach
lutach's Avatar
05.22.2008, 01:44 PM
Some more.
ID:	4662   Click image for larger version
ID:	4663   Click image for larger version
lutach
lutach's Avatar
And more.
ID:	4666   Click image for larger version
ID:	4667   Click image for larger version
lutach
lutach's Avatar
05.22.2008, 01:46 PM
Last 2. Sorry.
ID:	4670   Click image for larger version
lutach
lutach's Avatar
05.22.2008, 01:51 PM
Now let me explain the ugliness. I was going to use shrink wrap, but most of the controllers I have with shrink wrap seems to make it shrink some more. So I had some of that Self Fusing Silicone Rubber tape here and decided to try it out. One advantage is that it will withstand higher heat and it should harden a bit in a few hours. You can also see that it makes for a much more water tight application. It also smells like my uncle's rubber factory . I will find my on/off switch and add it to the fan and use my rx pack that's already in the truck to run the fan. I don't need the rx as the BEC on this controller is just doing a great job and hasn't failed yet. Hope your guys enjoy my Frankenstein job .
jzemaxx
What Lipo capable is this one??? Just 5S??
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
lutach
lutach's Avatar
05.22.2008, 01:56 PM
It is 6S. Scorpion will be changing the PCB to make it a better controller and the HV ones (12S and 15S) will be available soon as well (I'm keeping my fingers crossed for the HV ones).
lutach
lutach's Avatar
05.22.2008, 05:22 PM
Got the controller mounted and fan working. Tomorrow I ill see how it does and hope fully it will stay cool.
ID:	4672   Click image for larger version
ID:	4673   Click image for larger version
lutach
lutach's Avatar
05.23.2008, 11:19 AM
Just came back from a quick run to see what was improved with the Heat Sink/Fan combo. I must admit, I've extremely impressed now. The controller performed very solid and didn't get hot at all. It was just warm and I guess the heat sink/fan made the difference. The Mega is getting a beating and it is just an awesome little motor. If Mega comes out with a sealed version of the ACn22 series, I'll be adding some to my collection.
Name:	MBX5T, Mega Acn22-30-2, Scorpion Commander 120A, 2 3S 2200mAh (22.2v)c.jpg
johnrobholmes
05.23.2008, 12:07 PM
Nice! Did you get this one straight from George?
---JRH---
lutach
lutach's Avatar
05.23.2008, 12:27 PM
Yes, I've been talking with him for a while now and I gave him some of my ideas. Georges is a great guy and he is open for suggestions. John, this controller changed after I installed the heat sink and fan. It's a monster now. I changed a few things on the setting and I'm going to try the reverse function, changed timing from auto to 15 degrees and I will see what the Motor Start Booster will do. I hope he can use the MOSFET I suggested and I will wait to see what he says.
johnrobholmes
05.23.2008, 12:49 PM
When you get bored with that one, I will take it off your hands if George will allow. I want to see how well it starts up an outrunner in a bind, more specifically the motors that George makes for me! I suppose I should just email him direct about it.
---JRH---
