Gustav
Gustav's Avatar
09.20.2005, 01:34 AM
Unless there's a kevlar spur for it, the only thing i can think of is to try a losi or associated spur and pads.
The pads and spur on my MF2 have never given me any trouble,and should fit your topshaft.I've not run them with as much power as yours yet (waiting for a lehner right now)but it's run many many hours with a ss5800 in the most high grip scenario you're likely to come across(dirt paws on grass,MF2 grip rolls!)with alot of slip and the kevlar spur is still in very good condition.
The spur has a 4.8mm hole but if you just run a 5mm drill through it should run pretty true on your top shaft.The pads are about 1.3 inch diameter(OD 33mm,ID 24mm,1mm thick) so would be getting full coverage from your plates,so in theory it should work perfectly on your top shaft with your slipper plates.
The parts are: pad(LOSA3123) they come single not pairs
86T kevlar 48p spur(LOSA3987) bigger than you want i know but maybe there's a smaller one that would work or you could use bigger pinions.
Edit:LOSA3981 78T 48p kevlar spur (uses same A3123 pads)
Obviously i can't know for sure if they will work without having an evader in front of me but for the cost of these parts i would give it a try.(i can't see why it wouldn't work at this point)
Anyway,i suggest trying that and if it doesn't work don't blame me
:L:
Hope this helps,if not,oh well at least i tried.:C:
What mini you gonna do.A home for your Mamba?The X ray M18T is out now and might be worth a look when there's more parts available.
