kostaktinos_mt
05.11.2008, 01:31 PM
clutches do a really good work at eliminating cogging and smooth-ening out current 'spikes'... with a 'conservative' pinion, you would see a bit higher temps and a lot higher current peaks...
just my 0.02...
  Send a message via MSN to kostaktinos_mt
cdis
05.11.2008, 06:42 PM
I could run 2p as I've got 2 5S packs. Problem is, with 2 packs the revo is PHAT lol.
Also, its way unbalanced in the air with almost .5kg of batteries on one side lol.
I guess I'm just trying to avoid running 5s2p to keep the weight off, but I guess I will run 2p if I have to. I've tried a run with 5s2p and there was only a marginal increase in amp draw, which I put down to the motor having to push the extra weight around.
I'm using the DPRII-150, 150 amp version.
