DickyT
05.12.2008, 06:36 PM
Originally Posted by lxmuff View Post
Could the external CCBEC be used on the Monster? It in itself has been very reliable, at least for the short term.
some have worked with external, mine will not power on with external power.
I'm considering putting an external bec on mine when it arrives after the luck I had with the first.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
05.12.2008, 07:42 PM
The initial production was way more than 50-60 units.... I thought i heard something about 1500 once. I saw at least 200 myself at the shop the other day.
Sounded like a BEC issue, and I'm sure the guys will track it down and fix it. I wonder it the production units had a changed component from the prototypes, or a bad batch of components... something unexpected. It happens.
Honestly, I'm a little concerned with running mine now too... but that's the only way to find out how it's going to do.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
05.12.2008, 08:40 PM
just sent my monster in and it should arrive in kansas sometime next week....luckily i ordered one from mike and I hope its from the 2nd batch... but castle has always had great customer service and make top notch products and I'm sure these dying monsters are just part of the regular mass production mishaps that happen with just about any product that is mass produced...besides only one of my batteries are 5s the rest are 4s.....and i agree with you too dickyt i might end up running the CC BEC once i get this one back just to be on the safe side...
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
azjc
05.12.2008, 08:59 PM
I would just run it like you would normally, and if something happens CC will take care of you...they have a very liberal return policy, they will send you a replacement before you send them the defective part
