azjc
05.12.2008, 10:50 PM
you can go as low as 3 volts per cell, I like to set mine @3.3 volts per cell...I have noticed when set at 3.0 vpc you will see a noticable dropoff in performance before it hits the LVC
05.12.2008, 10:56 PM
I noticed the same thing. I set my lvc a bit higher, like 3.1v to 3.2v per cell. I like the extra insurance, just in case the pack goes out of balance. Plus it is a good idea if you are running a pair of packs in series. One pack may be slightly better than the other and the weaker could drop below 3v per cell, while the stronger has enough voltage to keep the lvc from kicking in.
