bl-is-future
bl-is-future's Avatar
05.13.2008, 11:13 AM
I think that may depend on the size of the dent. I would suggest monitoring lipos constantly anyway. I think if it is not puffed now after 2 cycles with the dent then it probably will be fine. If it does turn out to be a problem you can always take the dented cell off and run it with one less cell. I have had many many maxamps packs and i would get puffed cells and just make new ones out of the remaining good cells. Out of 2 2s and 1 3s i am left with 1 4s. So out of 7s i have 4s left. But i will say once i sorted out the bad cells the 4s has been running good ever since. Oh and if some says you don't need to balance well i am here to say you do. I trashed a nice thunder power 3s because it was not balanced, i know balance every time.
lutach
lutach's Avatar
05.13.2008, 03:40 PM
I have dented a few and I watched them carefully, but after a couple days I charged them up and they are running good still. I heard of guy who bent lipos a little and they still work perfectly. The big problem would be if the pack has a puncture.
