Django
05.13.2008, 02:28 PM
I have this same problem with my Hyperion 0606i. Putting a meter on the adapter I see 14.4 volts out of the two 7 cell packs. Each pack charges fine separately.
My thread over at NK.
http://www.nitrokillers.com/showthread.php?t=1277
Post any updates please. I'll do the same.
JThiessen
JThiessen's Avatar
05.13.2008, 08:49 PM
I did some measurement's tonight, and at first it looked as though I was trying to charge full batteries, as they measured 15.XX V. When I pressed charge, the V display initially read 15.XX V, it ran up to about 20.X V, then back down to 15.XX volts. It then beeps and gives "-1.44 Err".
I tried to discharge them, but it shows an empty cell in the display, and reads 0.0V, 0.00 mAh. It keeps cycling though, but the numbers dont change.
I sent another more detailed email to them tonight, hopefully they will give more help tomorrow. I have a feeling that they are going to make me purchase an adaptor before they will believe it could possibly be the charger.
JThiessen
JThiessen's Avatar
05.24.2008, 11:00 PM
Update:
A week ago, I ordered an adaptor from MaxAmps, just to either rule out the one I made, or confirm it as the culprit.
I hooked up a pair of gp3300's, set it on autocycle, and it appears to function correctly. They charged up to 15.84V.
I tried the same with my IB4200's, but I'm still having problems with them. I think the charger is acting correctly. They will only charge up to 9.8V. I may have one of the infamous bad IB cells. Anyone have any tips or tricks to try to resurect a bad one? I'm currently trying to auto cycle them a couple times to see if that may help.
So it appears that even though my adaptor provided measurements that seemed correct, something was impedeing the electron flow - exactly why I became a Mechanical Engineer, not a Sparky!!
05.24.2008, 11:25 PM
I have a superbrain 989, and have made quite a few adapters to charge multiple packs. I even made on to charge 3 6 cell packs in series. I have overvolt errors every so often. I usually let it beep after I hit start, then hit start again and it will work properly.
JThiessen
JThiessen's Avatar
05.25.2008, 01:24 PM
What exactly is an over volt error, and what does it mean? Is that what my error code meant ("err -1.44V)?
BTW, my second autocycle on the IB's dropped them down to 7.05 volts. Appears they are dying
