You can use the Kyosho 46t plastic spur gear that RC-Monster carries, and it is advisable to use to reduce wear on the pinion and to also decrease the noise between the gears (steel pinion + steel spur is pretty loud).
ok thanks for all the help now about the liop charging it do i charge it all the and when i drive do i let it go all the way down?
