bl-is-future
bl-is-future's Avatar
05.15.2008, 02:28 PM
Originally Posted by phatmonk View Post
My MA 4S2p 6000 pack says max continuous discharge 125 amps.And my Neu 1515/1.5d is rated at 120 amps.Sooo exactly what does this mean?
It means you need MORE POWER! No just kidding, the battery can put out a constant 125 amps to the ESC. So if your battery rating is lower than the ESC rating it will not work very well. Ex... a constant 20 amp battery will not work on a MMM very well. Will stress the battery too much and possibly cause fires, explosions, and/or bodily harm.
The motor rating i am not sure of. Maybe the max amps it can pull or take from the ESC?????
bl-is-future
05.15.2008, 02:34 PM
to run a 15c battery you need at least 5000mah. That is exactly 75amps cont.
Just use this formula - (c rating * mah) / 1000
If it equals 75 you are good to go!
The higher the number after the formula the better, but not always necessary.
