lutach
lutach's Avatar
05.16.2008, 04:25 PM
When you swaped the l length shaft/rotor in what kv did you end up with? Was it similar to the 13l, they output wires look to be the same diameter.
I have a 13l, 14l, and an 8l, and the 8l has much thicker wires coming out of it.
Didn't run it yet . I'm not sure if I will. I might just put the rotor back in the 13L and do some surgery on my Mr. C MBX5T kit to make it fit. I'm also undecided if I should go with the C50-13L or the ION-X that sems to be a C50-13XL, but gray instead of purple (Barney drives me crazy, I any Barney I see). I was thinking of removing the purple from all my motors .
