dpb318
05.18.2008, 11:59 PM
yeah this kit is very good, even with the few minor errors such as the servo plate brace and the tranny holes not lining up. those are very small problems that were easy to fix, this kit is well worth its money
i found it kind of fun not having directions, it was fun to just play with it and figure out how it all goes together (although i did have to cheat a few times and check this site)
for the battery im going to make a hard "shell" for it out of plexiglass since ill be bashing with lipo so that should help disperse the force of the small battery stops
Dewmerz
05.19.2008, 12:43 AM
Make a good battery stop to use closest to the spur instead of the delrin stop. Killjoyken made one for his using two of the tabs to screw on the bottom skid plate. The two tabs were replaced with one of the cross braces from the stock kit and already had holes drilled lining up with the skid plate. Ken made me the same battery stop after we talked about this. Eight inch velcro loops work well to keep the battery pinned against the outside rail.
http://www.rc-monster.com/forum/showthread.php?t=11741
