bdebde
That's All Folks!
bdebde's Avatar
05.19.2008, 10:26 PM
You can also use shims on the outside of the bearings.
05.19.2008, 10:31 PM
One gasket worked for me, but the gaskets are different thickness depending on mfg. Do not use one and see if the diff is too tight. If not just use silicone sealant to prevent leaks. Or if it is too tight just use one gasket, and shim the bearings to get a good fit in the bulks like bdebde said.
