05.21.2008, 06:11 PM
Originally Posted by DLS II View Post
That's right where I want to be. I'll be using a 4s a123 pack(13.2 volts). An outrunner with a KV of 1000 would produce 13200 rpm which should give a speed of 40-45 mph. I was also concerned about torque- would the motor I selected (Rimfire 42-50-1000) have enough? Don
I would go up to 5s a123 and a lower kv motor. Startup load is high with a direct to diff outrunner, and the more voltage you have the better it will run. I guess you plan to run a MM? Or maybe the MMM?
Your rimfire motor should be ok, but I would go with the 42-60-800. What are your diff ratios and tire size?
