zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.25.2008, 06:11 PM
Yes, I forgot to mention the paddle tires, that really does suck alot of juice when running on sand, or any loose surface. UBEC will help also. What speed are you geared for? Because if you are geared for over 37-40mph with only 2s2p A123, you WILL have current problems, hence heat problems.
