evader
05.26.2008, 09:13 AM
ok, I'll try some new batteries. I've just been using the ones that came with it...so I really don't know how good they are or aren't. What batteries should I use? I've got a few fairly new 3000 packs that I put in my sons emaxx for him. Would those be decent enough to use just to see if that's the problem or do I need something better than that?
Dafni
Dafni's Avatar
05.26.2008, 09:28 AM
Basically new NiMH cells should do the trick. But decent Lipos would show you the real potential of your setup.
evader
05.26.2008, 10:08 AM
Thanks. I think I'll hold off on getting any lipos until I figure out if this truck will even work properly or not
GriffinRU
05.26.2008, 11:36 AM
Good call Daniel, but he still needs to restore connector, otherwise he cannot re-program it or cannot enable/disable BEC, I do not know which one is broken i.e. close to the board edge (usual suspect, programming jumper) or second one from boards edge (enable/disable BEC). If it is BEC's jumper than he is Ok because he doesn't need it, better be disabled, but if not then restoration required.
To evader:
You can send it to me and I will recover it for you, just cover the shipment cost ($5.00 by priority mail). If you want I can add couple goodies to your ESC to improve it a little bit. If interested send me PM.
