alright so less than half the price of the one on ebay for something that will be just as good if not better... will there be a noticeable difference in the truck? or is it something that just kinda helps smooth everything out? worth $10?
Should help temps by 10 to 20 deg. I would run a ccbec and disable the mm internal bec. That will drop temps on the esc quite a bit, and is definately worth 20bucks. Plus the ccbec is adjustable via the castle link. Out of the two, the bec will be the better mod for 3s use.
