05.28.2008, 08:56 PM
I was thinking the same thing. I should buy a couple of 5s, then I could use the smaller motor and get better run times.
VintageMA
VintageMA's Avatar
05.28.2008, 09:13 PM
What ESC are you planning to run? If you are going to the MMM then you could consider up to 6S for a very efficient system with cool long runtimes.
1515/2D (2050kv) - 4S @ ~5000mAh (74W/hr) (30,340rpm)
1515/2.5D (1650kv) - 5S @ ~3900mAh (72.15W/hr) (30,525rpm)
1515/1.5Y (1500kv) - 6S @ ~3300mAh (73.26W/hr) (33,300rpm)
As you can see all 3 combinations have about the same rpms, the same Watt-hour capacity and about the same battery weight. Yet the 6S setup will be the most efficient and coolest running.
“Everyone has a right to be stupid; some people just abuse the privilege.”
