Jeremy1976
05.30.2008, 06:01 PM
A servo is like a mini-system in one package since it contains an ESC, gearing, and motor. If you up the voltage, the current will increase too (since changing the gearing is not something most people do). As long as the "system" inside the servo case can handle everything (heat, current, voltage), it'll last.
And end points adjusted properly!
