speed demon
06.03.2008, 08:53 PM
Wow looks like I started something.
Let's say for instance on my rustler with the medusa motor running 4S then putting in a 5S but gear it down too the same speed will I have the same run time given both bats are the same mah?
I just got done doing some speed runs geared 35/76 and it's fast but want to go more but I'm out of room for more gear unless I go milling out the slot on the motor plate.
Would like to get abit more run time but have enough power to gear up for some sick speed(with a 5S) and keep my motor nice and cool.
My MM with fan now was 121 with the 5 tooth larger gear. My motor was up to 136 but without the fan for over half the run(nasty end over end over end over end crash). Thanks
skellyo
skellyo's Avatar
06.03.2008, 09:49 PM
It's unlikely that scenario will happen. You'd have to make sure that the gear reduction itself reduces the current draw by roughly 20% with the 5S setup. I'm not sure that gearing for the same speed with both batts would do that. I think the only way you would really know how close you can match the current draw of the setups is to run them on an Eagletree or similar datalogger.
