DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.28.2008, 09:14 PM
lol, I actually got 30 minutes more before it came apart. The track was so rough I didn't really notice it till it was nearly off
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
06.29.2008, 07:18 PM
Nice conversion...and pics. I am jealous of you having that nice a track near you. Nearest one to me is 2.5hrs away.
DRIFT_BUGGY
06.29.2008, 07:24 PM
My wife just got a new Camera and she wanted to test it out so she was all excited to go down to the track and take photos of my buggy
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.29.2008, 09:52 PM
Well went down to the track today but unsure on what run time was I wasn't really paying attention, was more concerned about try to keep the temp down. I changed the timing from 10 degree down to 3 degree and cut a large hole in the front cover to get more air flow to the bearing. After about 8 minutes of running I bought it into the pits to check the temp and the motor was up at 170F, ESC at 128F and battery around 105F. Going to know change to 0 degree motor timing and put a larger 15T pinon in instead of a 14T which is what I have in at the moment. I will also change the centre diff fluid from 5000 (standard in the roller, non roller is 7000) to either 7000 or 10 000 but don't have the diff fluid yet, still in transit.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.30.2008, 06:23 PM
Well I tried to grind down the Motech Skid Plates down on the very front so I could put them on. Didn't end up working so I have the front skid plate just held up on the 2 rear screws. See how that goes. Got no problem with the rear one, only the 2 screws up the very front with the bumper. 8-32 x 1/2" is the longest screws I could find with a flat head and that is what the chassis already has.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.30.2008, 11:38 PM
Took it down to the track today. Temps stayed around the 165F mark, it did get up to 176F at one stage. After 28 minutes of running (on same battery) the motor came loose and stripped some of my spur gear. Im not going to run it again now until my Diff Fluid arrives. Will be changing from F 3000 C 5000 R 2000 to F 7000 C 10 000 R 3000. Have no issues at all with the MMM. Running strong as and temps are pretty low 115F mark. Awesome ESC, standard fan is strong running strong aswell. Was expecting more issues with the ESC than the motor with this build.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
07.01.2008, 12:36 AM
Keep the updates coming. It's good to hear how this is coming along. What are you going to do about the spur gear.
DRIFT_BUGGY
07.01.2008, 12:58 AM
I got a new Kyosho 46T in my cupboard that I bought for a spare incase anything like this happened. The one currently on the buggy isn't completly stripped but makes a loud noise now when driving
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
TDC57
TDC57's Avatar
07.04.2008, 05:04 AM
Hay DB,
I've got a 46T I can ship you off a XRay if you want to pay for the postage (?).
Your call either way, regardless I must say that I enjoy reading your updates, I feel your pain.
Have a great 4th..
Shaun.
Nothing!.. Hahahahaaa..
DRIFT_BUGGY
07.04.2008, 05:23 PM
No, its right Shaun, got a spare one anyway and also have another spare one coming with the diff fluid I ordered, thanks anyway
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
07.09.2008, 12:33 AM
Diff Fluid arrived today. Ordered from Amain and it arrived here in Australia in 1 week (not express) Changed my mind and going to leave the rear at 2000, put 5000 in front and 10 000 in center. When I pulled my center diff apart there was no much fluid in there at all. Won't get a chance to test it out today. Had alot of rain over the last few days so track is probably still wet.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
07.16.2008, 10:22 PM
Well finally the rain went away and I managed to get down to my local track. Using the 13T pinion and changing from 3000 in front diff and changing 5000 in centre to 10 000 couldn't wait to see of the changes. At 10.32am I was going out of the pit lane and flying down the main straight. At 11.17am I was driving back into the pits as battery was starting to run slow. 45 MINUTES OF RUNTIME I never had to turn off the battery once, just kept going and going. Temps were Motor - 160F, ESC 111F & Battery 108F. I checked the voltage of the battery with the multimeter and it was 16.45V. I charged up this battery about 3 - 3 1/2 weeks ago. Back to work tomorrow, so not going to be able to use it for another 5 days.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
07.17.2008, 02:58 AM
all i can say is wow. what capacity were u using? 5000 or 6000 im guessing, any more than that and it wouldnt fit!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
07.17.2008, 03:21 AM
TP 5S 5000 25C. I was probably flat out racing 60% of the time, 38% was doing sections over and over trying to get the right line and the other 2% was on my roof from landing wrong.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
mxracer
08.01.2008, 04:43 AM
i have no idea how the hell you get runtimes like that , this is my setup
neu 1512 2.d/f
hyper st pro truggy
52/12 gearing
mamba max , 15v cutoff voltage
5s flight power 4900mah
everything is pretty close to the same as yours , yet i get about 9-12 mins runtime
i have a jammin cr pro buggy , i will try replacate your setup as close as possible , but i very very much doubt i will gain another 30 mins of runtime
HOW DO U DO IT ??
losi 8ight-t 1515 tekno 1Y/MM 4s/5S flightpower
losi 8ight-t 1515 tekno 1y/MM 4s/5S flight power
RIP 4x MMM . MM still lives on !
