GriffinRU
06.07.2008, 09:12 PM
What's constructive about being intentionally insulting, and calling people stupid? Until that last post, I thought it might be a cultural thing. Thank you for clearing it up for me.
I'm looking forward to seeing your designs on the hobby store shelves.
I can put my sticker on modded MambaMax controllers? :)
Pdelcast
Pdelcast's Avatar
06.07.2008, 09:18 PM
Sure. We could even change the caps and add the TVS for you.
Patrick del Castillo
President, Principle Engineer
Sammus
Sammus's Avatar
06.07.2008, 09:20 PM
Don't forget to use different heatsink goo too
Pdelcast
Pdelcast's Avatar
06.07.2008, 09:23 PM
Nope, the goo is GriffinRUs deal -- he'll have to put the goo on himself.
GriffinRU
06.07.2008, 09:21 PM
Fantastic! That what I was looking for. Can you add copper plate? And 5-6S support?
Pdelcast
Pdelcast's Avatar
06.07.2008, 09:31 PM
You do know that the copper plate and the Artic silver doesn't really make much difference right? What would make a big difference is to go to a pin-fin copper heat sink... like this one:
http://www.coolinnovations.com/produ...UltraCool4.php
GriffinRU
06.07.2008, 09:43 PM
Try to take an infrared picture of your ESC with and without copper plate, I do not really care about arctic silver...as long as you can keep it as flat as possible, you can use graphite if you can maintain below 0.005". You know there is a step with sand paper right, not only for adhesion.
Sure, there are even better things you can do. If your R&D budget can afford 2 month clean-room run, I can share with you what can be better and we can talk patenting...
Pdelcast
Pdelcast's Avatar
06.07.2008, 09:58 PM
I have IR pictures of the ESC, and a copper plate doesn't make any significant difference on the 6oz board... the older 4oz board was a different story. And, a copper pin fin heatsink is actually an easier mod will have much more effect than a copper heat spreader.
BTW -- we are using the temp sensor on the processor -- so make sure any mods you do reduce the temp difference between the FETs and the processor, not the opposite.
What does that mean -- 2 month clean-room run? Are you thinking about getting On Semiconductor to give us some Fab time, or what?
GriffinRU
06.07.2008, 10:20 PM
Well, true for the last gen. pcb with only 6 fet's down there... still can see slight improvement. If you plan to add copper heatsink to MM, than I am sorry who needs MMM in 1/8 scale? You can do the same to MMM, of course. Just get plated copper, so it doesn't change its appeal :)
I know, on first versions I was adding copper spacer, but lately reusing your foam, works alright. :)
Something like that, but not at On Semiconductor, more like proto run at University and upon success, I do not know it is way too early.
06.09.2008, 01:57 PM
Is this a potential option for a more expensive MMM that doesn't need a fan? :)
Cheers
